Rear Speaker Wiring
stevlor
Rear Speaker Wiring
Post by stevlor » Wed Sep 14, 2016 8:49 pm
Hi everyone,
Rear speakers haven't worked since I bought my Bongo, and was hoping to install some new ones. I did a search on here and found that while it seems to be a common thing for the rear speakers not to be there at all, most people mentioned having the wiring already in place ready for a set to be installed. I pulled the o/s panel back (breaking a few clips in the process, no idea how you guys get it off without snapping things!) and could only see what I think is the cable for the petrol cap opener, and then a cable heading to the rear lights. Not sure if I'm missing something - what would it look like? And if there's nothing, I'm guessing that fitting rear speakers would mean quite a long job running wires from the cd player?
Not sure if the picture is much use: https://drive.google.com/file/d/1ttwBuw ... uOOQw/view
Re: Rear Speaker Wiring
Post by g8dhe » Wed Sep 14, 2016 9:52 pm
Usually a small two pin socket taped up to the loom, ready to be plugged in to the speaker plug.
stevlor
Post by stevlor » Tue Oct 04, 2016 4:46 pm
Thanks, unfortunately I can't see anything like that - so I'm guessing that installing rear speakers would involve a slightly bigger job!
