rear suspension
Sidb
rear suspension
Post by Sidb » Thu Aug 04, 2016 4:59 pm
New to Bongo Fury
I have just had full rear suspension changed and one of the shockers is knocking all the time was told it is the hanger where the top of the shocker hangs on and it needs replacing can you buy this part or am I going to have to get one made.
Re: rear suspension
Post by Ian » Thu Aug 04, 2016 6:00 pm
You can get new ones, but they are very expensive and have to come from Japan. For second hand, try George at www.bongospares.co.uk
Sidb
Re: rear suspension
Post by Sidb » Thu Aug 04, 2016 6:10 pm
Thank you very much ian
Re: rear suspension
Post by Bob » Thu Aug 04, 2016 7:14 pm
Welcome aboard, Sid. :D
Re: rear suspension
Post by teenmal » Sat Aug 06, 2016 3:01 pm
Ian wrote:You can get new ones, but they are very expensive and have to come from Japan. For second hand, try George at http://www.bongospares.co.uk
Can you tell us the cost and the part number please.
Sidb
Re: rear suspension
Post by Sidb » Thu Aug 11, 2016 12:04 pm
Ref:Rear shocker hanging bracket,
I have been incontact with AMAYAMA SINGAPORE PTE LTD and they can not find this part in there catalogue looks like I am going to have to get part made.
Bongolia
Re: rear suspension
Post by Bongolia » Thu Aug 11, 2016 1:41 pm
Can you put up an image of the part you need?
Sidb
Re: rear suspension
Post by Sidb » Thu Aug 11, 2016 7:04 pm
I will try and get a picture image of part I need as soon as I can get into a garage and get it up on the ramps
Sidb
Re: rear suspension
Post by Sidb » Thu Aug 18, 2016 1:54 am
I have found out you can not buy rear shocker brackets you have to buy full number 5 rear cross member which has rear shocker hanging brackets welded to it.
Re: rear suspension
Post by mikeonb4c » Thu Aug 18, 2016 8:20 am
Sidb wrote:I have found out you can not buy rear shocker brackets you have to buy full number 5 rear cross member which has rear shocker hanging brackets welded to it.
Blimey - that sounds like a major undertaking?
Bongolia
Re: rear suspension
Post by Bongolia » Thu Aug 18, 2016 9:02 am
A decent non franchise bodyshop would be able to make up something.
I have restored many cars in the past and nothing is impossible when it comes to body repair its a question of economics usually.
Look for a smaller repairer who does restorations.
Re: rear suspension
Post by mikeonb4c » Thu Aug 18, 2016 9:31 am
Bongolia wrote:A decent non franchise bodyshop would be able to make up something.
That was my suspicion also, good to hear it from someone whose background gives weight to their words.
Sidb
Re: rear suspension
Post by Sidb » Fri Aug 26, 2016 11:54 am
Just to let every body know I got my rear shocker bracket sorted took it to a Engineering Company they built bracket up and re-threaded now all is ok.
