rear suspension
rear suspension
New to Bongo Fury
I have just had full rear suspension changed and one of the shockers is knocking all the time was told it is the hanger where the top of the shocker hangs on and it needs replacing can you buy this part or am I going to have to get one made.
Re: rear suspension
You can get new ones, but they are very expensive and have to come from Japan. For second hand, try George at www.bongospares.co.uk
Re: rear suspension
Thank you very much ian
Re: rear suspension
Welcome aboard, Sid.
Re: rear suspension
Can you tell us the cost and the part number please.Ian wrote:You can get new ones, but they are very expensive and have to come from Japan. For second hand, try George at http://www.bongospares.co.uk
Re: rear suspension
Ref:Rear shocker hanging bracket,
I have been incontact with AMAYAMA SINGAPORE PTE LTD and they can not find this part in there catalogue looks like I am going to have to get part made.
Re: rear suspension
Can you put up an image of the part you need?
Re: rear suspension
I will try and get a picture image of part I need as soon as I can get into a garage and get it up on the ramps
Re: rear suspension
I have found out you can not buy rear shocker brackets you have to buy full number 5 rear cross member which has rear shocker hanging brackets welded to it.
Re: rear suspension
Blimey - that sounds like a major undertaking?Sidb wrote:I have found out you can not buy rear shocker brackets you have to buy full number 5 rear cross member which has rear shocker hanging brackets welded to it.
Re: rear suspension
A decent non franchise bodyshop would be able to make up something.
I have restored many cars in the past and nothing is impossible when it comes to body repair its a question of economics usually.
Look for a smaller repairer who does restorations.
Re: rear suspension
That was my suspicion also, good to hear it from someone whose background gives weight to their words.Bongolia wrote:A decent non franchise bodyshop would be able to make up something.
Re: rear suspension
Just to let every body know I got my rear shocker bracket sorted took it to a Engineering Company they built bracket up and re-threaded now all is ok.
