Auto gearbox identification plate
wattg
Post by wattg » Wed Oct 15, 2014 6:54 pm
I am currently sourcing a second hand gearbox for my 2.5 4x4 auto and have been asked to give them the ID number off a plate on the gearbox. But I can't find it. Can anyone help me with photos if poss as to where I will find this plate?
Re: Auto gearbox identification plate
Post by Bob » Wed Oct 15, 2014 7:18 pm
Can't see the reason for this as I thought they were all the same.
Someone will likely know more.
Too dark to crawl under Bongy I'm afraid.
Post by Simon Jones » Wed Oct 15, 2014 8:07 pm
There should be a metal plate on the near side rear with the make and model (or at least there is on my 2WD V6). Later gearboxes are slightly different. Further reading: http://www.igmaynard.co.uk/bongo/member ... earbox.pdf
Post by rita » Thu Oct 16, 2014 8:44 am
I seem to remember that you changed the box a few months ago, this box might have a different code to the original.do you still have the faulty box that you removed.
Ask the person that you are dealing with if the VIN will be sufficient.
Good Luck.
