Auto gearbox identification plate
I am currently sourcing a second hand gearbox for my 2.5 4x4 auto and have been asked to give them the ID number off a plate on the gearbox. But I can't find it. Can anyone help me with photos if poss as to where I will find this plate?
Re: Auto gearbox identification plate
Can't see the reason for this as I thought they were all the same.
Someone will likely know more.
Too dark to crawl under Bongy I'm afraid.
There should be a metal plate on the near side rear with the make and model (or at least there is on my 2WD V6). Later gearboxes are slightly different. Further reading: http://www.igmaynard.co.uk/bongo/member ... earbox.pdf
I seem to remember that you changed the box a few months ago, this box might have a different code to the original.do you still have the faulty box that you removed.
Ask the person that you are dealing with if the VIN will be sufficient.
Good Luck.
Good Luck.
