Haydn Alarm LCD Bulb Change
- Tribal Elder
Is is possible to change the bulb on the display an the LCD display? I'm a fussy bugger & it doesn't match the colour of the dash illumination.
Re: Haydn Alarm LCD Bulb Change
But....but.....but....the only time it's on is when you are likely to have other things on your mind?Mark Elvin wrote:Is is possible to change the bulb on the display an the LCD display? I'm a fussy bugger & it doesn't match the colour of the dash illumination.
Sorry, that's not an answer! It'll be interesting to see what the lca people say - so long since I fitted mine I can't remember.
- Simon Jones
Most LCDs use surface mounted LEDs fixed to the PCB so changeable but only if you are experienced in working with s/m components.
- Tribal Elder
Good job we have a decent electronics manufacturing department!!!!Simon Jones wrote:Most LCDs use surface mounted LEDs fixed to the PCB so changeable but only if you are experienced in working with s/m components.
- haydn callow
Are you talking about a Low Coolant Alarm or a TM2 temp alarm??
- Tribal Elder
TM2 COMBINATION
- haydn callow
You could take the lid off and change the LCA alarm bulb if you can solder. Don't try and interfere with the TM2 bulb....but what's the point? It's only on for 1 sec when you switch on, any other time and you will spot the red amongst all your other lights.
Best advice...leave well alone.
- Tribal Elder
tHE LCD ILLUMINATION IS WHITE ALSO.
- haydn callow
You cannot change the LCD
- Tribal Elder
It's the illumination of the LCD I want to change. Not the warning light or LCD itself.
- haydn callow
Carnt be done
