Haydn Alarm LCD Bulb Change
Mark Elvin
Post by Mark Elvin » Tue Oct 14, 2014 7:31 am
Is is possible to change the bulb on the display an the LCD display? I'm a fussy bugger & it doesn't match the colour of the dash illumination.
Re: Haydn Alarm LCD Bulb Change
Post by mikeonb4c » Tue Oct 14, 2014 7:57 am
Mark Elvin wrote:Is is possible to change the bulb on the display an the LCD display? I'm a fussy bugger & it doesn't match the colour of the dash illumination.
But....but.....but....the only time it's on is when you are likely to have other things on your mind? :roll:
Sorry, that's not an answer! It'll be interesting to see what the lca people say - so long since I fitted mine I can't remember.
Simon Jones
Post by Simon Jones » Tue Oct 14, 2014 8:10 am
Most LCDs use surface mounted LEDs fixed to the PCB so changeable but only if you are experienced in working with s/m components.
Mark Elvin
Post by Mark Elvin » Tue Oct 14, 2014 8:24 am
Simon Jones wrote:Most LCDs use surface mounted LEDs fixed to the PCB so changeable but only if you are experienced in working with s/m components.
Good job we have a decent electronics manufacturing department!!!!
haydn callow
Post by haydn callow » Tue Oct 14, 2014 9:50 am
Are you talking about a Low Coolant Alarm or a TM2 temp alarm??
http://www.coolantalarm.co.uk
Also BMW Clocks
Mark Elvin
Post by Mark Elvin » Tue Oct 14, 2014 11:32 am
TM2 COMBINATION
haydn callow
Post by haydn callow » Tue Oct 14, 2014 12:09 pm
You could take the lid off and change the LCA alarm bulb if you can solder. Don't try and interfere with the TM2 bulb....but what's the point? It's only on for 1 sec when you switch on, any other time and you will spot the red amongst all your other lights.
Best advice...leave well alone.
Also BMW Clocks
Mark Elvin
Post by Mark Elvin » Tue Oct 14, 2014 12:30 pm
tHE LCD ILLUMINATION IS WHITE ALSO.
haydn callow
Post by haydn callow » Tue Oct 14, 2014 2:39 pm
You cannot change the LCD
Also BMW Clocks
Mark Elvin
Post by Mark Elvin » Tue Oct 14, 2014 3:09 pm
It's the illumination of the LCD I want to change. Not the warning light or LCD itself.
haydn callow
Post by haydn callow » Tue Oct 14, 2014 3:41 pm
Carnt be done
Also BMW Clocks
