someone has said you have to do something behind the fuse board
wiring
wiring
hi does anyone know how to make my bongo so as I can use the water pump and blinds with out the ignition on ??
1996 2.5 TD white over silver aft bongo
- mikeWalsall
Re: wiring
You would need to see what fuse is feeding which circuit ..
Remove the fuse(s) .. then take a separate fused wire from the positive side of the leisure battery and 'plug it into the vacant fuses 'feed' ..
Or you can buy a purpose made harness to do the job ..
Re: wiring
ok cheers is this just a test tool or a perment fix ??
- mikeWalsall
Re: wiring
The picture is for a kit tailor made for the automatic Bongo .. and is a "professional" fix ..
Re: wiring
I have got two batterys on my van but how do I tell if I have a split charger
Re: wiring
Nobody else has questioned it so I will. What water pump do you have connected up to the starter battery and why?IOWBongo wrote:hi does anyone know how to make my bongo so as I can use the water pump and blinds with out the ignition on ??
Re: wiring
on his sink maybe
to tell if you have a split charge or not.
has the bongo got a switch near the drivers knee with an engine symbol on it ?.
yes could mean that it is north jap model with 2 usually smaller starter only batts fitted. (but may have been converted).
no, could mean it may have.
check for how the 2 bats are connected. is there a straight, unbroken heavy link wire from the neg on the starter bat to the positive on the second bat. if yes its usually 2 starter bats in series.
if no then its usually a starter bat and leisure bat. (the leisure bat may actually be just a second standard looking battery, so sometimes not obvious).
look for a non standard looking relay with wires to the second bat, should also have a fuse box or in line fuses nearby to protect the system/circuits etc.
i use these, really good kit, then a seperate fuse box powering whatever you want powering off the leisure battery.
http://www.ebay.co.uk/itm/SPLIT-CHARGE- ... 1066905358
Re: wiring
Yes I guessed that too but why would anyone put a conversion in without a leisure battery?Northern Bongolow wrote:on his sink maybe.
- Simon Jones
Re: wiring
We're assuming they have a conversion
. All we know is there are two batteries, a pump (& possibly a tap) and some blinds. A photo of what you've got would help us give guidance on your options.
