someone has said you have to do something behind the fuse board
Nobody else has questioned it so I will. What water pump do you have connected up to the starter battery and why?IOWBongo wrote:hi does anyone know how to make my bongo so as I can use the water pump and blinds with out the ignition on ??
Yes I guessed that too but why would anyone put a conversion in without a leisure battery?Northern Bongolow wrote:on his sink maybe.
