coolant hose
cheekal
coolant hose
Post by cheekal » Thu May 09, 2013 9:04 pm
hi all
one of my coolant pipes is leaking it is the pipe under the pasenger seat which runs from just before the engine oil dipstick behind the alternator to a metal pipe on the left hand side.
Does any one know where i can get a replacement.
I have spoke to Bongo bits and they told me that they cannot get hold of this pipe but I would be ok to use 5/8 inch radiator hose is this correct.
Re: coolant hose
Post by Northern Bongolow » Thu May 09, 2013 10:43 pm
do you mean the little S shaped one on a diesel. or the U shaped one behind the alternator, order one from mazda,it will be here in 24 hours.
or contact ian at the bongo shop he has hoses in stock.
yorkee
Re: coolant hose
Post by yorkee » Fri May 10, 2013 4:10 am
Try the Lushprojects drawings also hosted on this site and you translate the diagram part number to a mazda number via the links on the left hand side of the drawing. Part number is in the format of WL011****. As mentioned previously you can order these direct from a mazda dealer and arrive in a few days if in Europe, a bit longer if via japan. There is no UK distribution network.
cheekal
Re: coolant hose
Post by cheekal » Fri May 10, 2013 7:35 am
Thanks for your help.
I think it might be a rear heater hose from the thermostat.
part number might be 61-214 but not listed on left hand side
Re: coolant hose
Post by Northern Bongolow » Fri May 10, 2013 9:16 pm
61-214 connects to Y.
check this link.
cheekal
Re: coolant hose
Post by cheekal » Tue May 21, 2013 11:58 am
Turned out to be part number 61-214
All fixed now
