hi all
one of my coolant pipes is leaking it is the pipe under the pasenger seat which runs from just before the engine oil dipstick behind the alternator to a metal pipe on the left hand side.
Does any one know where i can get a replacement.
I have spoke to Bongo bits and they told me that they cannot get hold of this pipe but I would be ok to use 5/8 inch radiator hose is this correct.
						coolant hose
Re: coolant hose
do you mean the little S shaped one on a diesel. or the U shaped one behind the alternator, order one from mazda,it will be here in 24 hours.
or contact ian at the bongo shop he has hoses in stock.
Re: coolant hose
Try the Lushprojects drawings also hosted on this site and you translate the diagram part number to a mazda number via the links on the left hand side of the drawing. Part number is  in the format of WL011****. As mentioned previously you can order these direct from a mazda dealer and arrive in a few days if in Europe, a bit longer if via japan. There is no UK distribution network.
						Re: coolant hose
Thanks for your help.
I think it might be a rear heater hose from the thermostat.
part number might be 61-214 but not listed on left hand side
Re: coolant hose
Turned out to be part number 61-214
All fixed now
						All fixed now
