Morning all,
I know alot of you have Pela pumps for shifting that pesky oil, and i think i should too.
Which model are you all using? I see there are a few 'professional' level ones, which do have a good capacity. Are the 'consumer' models ok, and is the 6l capacity enough to get it all out without problems? The oil filter will still hold a little anyway won't it?
So there you go, a whole load of questions for you.
Craig
Pela pump
Pela pump
Insert Bongo pun here
Re: Pela pump
Mine is 6l capacity, just keep an eye on it and empty it before it fills, then start again.
My view is you really don't need to spend the money on a professional model, unless yuo are going to use it many times a day like a garage would.
Good bit of kit I recon.
- Muzorewa
Re: Pela pump
I use the 6.5 litre version, just enough to catch it all before it spills onto the garden
The bottom one HERE
The bottom one HERE
Re: Pela pump
Done!
went for the 6000 from Machine Mart
just have to keep an eye on it overflowing
cheers peeps,
Craig
cheers peeps,
Craig
MountainGoat
Re: Pela pump
Wow you should have waited a bit Spit. The Machine Mart prices are a tad expensive, same pumps are cheaper from mailspeed Marine.
http://www.mailspeedmarine.com/tools-re ... 4535.bhtml
Tony
Tony
Re: Pela pump
good job their website seems to be faulty!
Put one in my basket, went to checkout, and it was gone! tried it a few times.
It must have a hole in the bottom...
