Pela pump
spitineye
Pela pump
Post by spitineye » Wed May 06, 2009 8:53 am
Morning all,
I know alot of you have Pela pumps for shifting that pesky oil, and i think i should too.
Which model are you all using? I see there are a few 'professional' level ones, which do have a good capacity. Are the 'consumer' models ok, and is the 6l capacity enough to get it all out without problems? The oil filter will still hold a little anyway won't it?
So there you go, a whole load of questions for you.
Craig
Insert Bongo pun here
Re: Pela pump
Post by Bob » Wed May 06, 2009 8:57 am
Mine is 6l capacity, just keep an eye on it and empty it before it fills, then start again.
My view is you really don't need to spend the money on a professional model, unless yuo are going to use it many times a day like a garage would.
Good bit of kit I recon. :D
Re: Pela pump
Post by Muzorewa » Wed May 06, 2009 9:19 am
I use the 6.5 litre version, just enough to catch it all before it spills onto the garden :D
The bottom one HERE
spitineye
Re: Pela pump
Post by spitineye » Wed May 06, 2009 9:49 am
Done! :D
went for the 6000 from Machine Mart
just have to keep an eye on it overflowing [-o<
cheers peeps,
Craig
MountainGoat
Re: Pela pump
Post by MountainGoat » Wed May 06, 2009 10:56 am
Wow you should have waited a bit Spit. The Machine Mart prices are a tad expensive, same pumps are cheaper from mailspeed Marine.
http://www.mailspeedmarine.com/tools-re ... 4535.bhtml
Tony
spitineye
Re: Pela pump
Post by spitineye » Wed May 06, 2009 2:34 pm
#-o
good job their website seems to be faulty!
Put one in my basket, went to checkout, and it was gone! tried it a few times.
It must have a hole in the bottom...
