abs sensor
willow2u
abs sensor
Post by willow2u » Tue Jun 30, 2020 2:41 pm
hi there first post, building a strange brew bongo and really need to ascertain whether the abs wheel sensors are just a 2 wire coil magnet which just produces an ac wave or fed a voltage and earth from abs controller making them a hall sensor with square wave output any advice much appreciated
Re: abs sensor
Post by g8dhe » Tue Jun 30, 2020 3:44 pm
Welcome!
2-wire coil sensor is all, there have been repairs made in the past worth searching but remember the search criteria has to have more than 3 letters in it :-)
search.php?keywords=front+wheel+sensor
willow2u
Re: abs sensor
Post by willow2u » Tue Jun 30, 2020 7:09 pm
Thanks for that I was hoping they were 2 wire hall sensors
Re: abs sensor
Post by g8dhe » Tue Jun 30, 2020 9:23 pm
Not from a design first implemented 20+ years ago!
willow2u
Re: abs sensor
Post by willow2u » Wed Jul 01, 2020 8:34 pm
Luckily enough I’ve found a converter that hopefully will enable the abs sensor to communicate with Ecu and speedo
Re: abs sensor
Post by g8dhe » Wed Jul 01, 2020 8:55 pm
Well if it works let us know here as the price of replacement ones are silly! Someone on here did rewind one as I recall ah yes viewtopic.php?p=697795#p697795
willow2u
Re: abs sensor
Post by willow2u » Thu Jul 16, 2020 8:58 pm
Have sourced an abs sensor which is spot on the cost was £2.75 brand new the mounting bracket rotates so cabn be used both sides just cut into existing wiring and solder on new connector and jobs a good one 👍
willow2u
Re: abs sensor
Post by willow2u » Thu Jul 16, 2020 9:16 pm
Can’t seem to upload photos
Re: abs sensor
Post by Bob » Thu Jul 16, 2020 10:24 pm
New method from the Bongomeister here:
viewtopic.php?f=4&t=77306
Just ignore the nonsense from one or two old lags. :wink:
willow2u
Re: abs sensor
Post by willow2u » Fri Jul 17, 2020 8:16 am
Re: abs sensor
Post by g8dhe » Fri Jul 17, 2020 12:05 pm
Where did you source the sensor?
willow2u
Re: abs sensor
Post by willow2u » Fri Jul 17, 2020 3:13 pm
i bought it from autodoc they were £5.80 on ebay and £2.75 from autodoc only downside was they charge £7 for delivery so in hindsight ebay is cheaper ive got some photos of part no on box but they are widely available stupidly enough the connector plugs are about £6 each but sure beats paying almost £200 for a "Bongo" abs sensor for the sake of a little soldering
Flanners
Re: abs sensor
Post by Flanners » Fri Jul 17, 2020 4:42 pm
Can you give the part numbers and make etc that you bought for future reference?
Re: abs sensor
Post by g8dhe » Fri Jul 17, 2020 5:05 pm
Humm not that many to choose from then;
willow2u
Re: abs sensor
Post by willow2u » Fri Jul 17, 2020 8:34 pm
Posting some photos of part
