What is this pipe? Coolant leak on 95 Bongo
bodiebongo2
Coolant leaked...All gone!!
Post by bodiebongo2 » Mon Apr 06, 2015 1:48 pm
So I went to go out in my bongo this morning and noticed a large puddle Underneath and all the coolant had leaked out. There is a large metal pipe under the bongo and near to the drivers side there is a crack in the pipe. I do have a photo but not sure how to add. I am supposed to be going camping tomorrow. Is there any way I can patch up the crack? Is it a big job? Help please! !
Simon Jones
Re: Coolant leaked...All gone!!
Post by Simon Jones » Mon Apr 06, 2015 1:59 pm
Don't risk it. Get a replacement pipe and ensure the coolant is properly bled before driving it anywhere.
Info on uploading photo here: http://igmaynard.co.uk/bongo/forum/view ... =42&t=9285
bodiebongo2
Post by bodiebongo2 » Mon Apr 06, 2015 2:37 pm
Thanks. I have lost a radiator before to a similar problem. I wad just hoping to still be able to go in holiday...boo!!
mikeWalsall
Post by mikeWalsall » Mon Apr 06, 2015 3:09 pm
With a Bongo may not only the radiator you will loose ..
Being mid engined .. if the job is not done right and the system bled 110% correctly they are prone to air blockages in the cooling system .. you then have a very good chance of the engine overheating and cracking the head ..
rita
Post by rita » Mon Apr 06, 2015 5:18 pm
Hi bodiebongo2 , what vehicle do you have.
bodiebongo2
Post by bodiebongo2 » Mon Apr 06, 2015 8:11 pm
This is a pic of my Bongo, the pic was taken underneath the drivers seat. All of the coolant has leaked out where it looks gunky near the clip. As you can see the pipe has also rusted. Does anyone know what the pipe is and how much it might cost to fix? The breakdown said to fill up the coolant with 4 litres of water and drive to my garage... not sure if this is wise?
silage
Re: What is this pipe? Coolant leak on 95 Bongo
Post by silage » Mon Apr 06, 2015 8:29 pm
don't drive it, get it picked up and taken to a bongo friendly garage.
" The harder you work, the richer you die"
97 4WD 2.5 TD
G0JZW
Post by g8dhe » Mon Apr 06, 2015 8:43 pm
Here are the piping diagrams (I thought these were bookmarked somewhere but can't find them?);
Post by Northern Bongolow » Mon Apr 06, 2015 9:06 pm
61-2d1 is the pipe thats leaking in geoffs links above.
have a read of this thread it may help.
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=58378
bodiebongo2
Post by bodiebongo2 » Mon Apr 06, 2015 9:19 pm
Thank you. Looks like a big job then... was supposed to be camping this week...dreading the bill :(
Post by Bob » Mon Apr 06, 2015 9:33 pm
Don't drive it.
If you are a handy DIYer carry on and fix the leak then bleed, otherwise its a flat bed to a Bongo Friendly garage.
Bloomin' pain when you're about to go away, but it needs fixing properly. :wink:
Post by mikeonb4c » Mon Apr 06, 2015 9:38 pm
bodiebongo2 wrote:Thank you. Looks like a big job then... was supposed to be camping this week...dreading the bill :(
Not necessarily. I opted to have a complete new pipe but my mechanic Adrian usually fixes them by cutting out the bad bit and fitting a t-piece, which is much cheaper on parts and labour (though a system refill and bleed is still required)
bodiebongo2
Post by bodiebongo2 » Mon Apr 06, 2015 10:03 pm
Ok great. Good to know I have a cheaper option =D>
Post by Ian » Mon Apr 06, 2015 10:11 pm
They are available in the Bongo Shop and are called "Rear Heater Supply Pipe (Driver Side)". Price is £85 including postage and VAT, discount for club members.
