smoking bongo
coolerking76
smoking bongo
hi i need HELP i have little to no knowledge of mechanics so here goes , my radiator burst in the bad weather so i took it to my local garage and he fitted a new on the when i go it back found the heaters were blowing cold the a few days later clouds of white smoke came bellowing out the exhaust for at lest the first mile or two not sure if the two problems are related. my local garage has since bled the system and fitted new glow plugs to find same problem. (96 n reg diesel )
Maty from netherton (wm)
Re: smokeing bongo
you drove it with a busted rad?
you might have cooked the head
- westonwarrior
Re: smokeing bongo
are you loosing coolant?
if so it does not look good
- haydn callow
Re: smokeing bongo
At any time...did the temp gauge move up to the HOT mark ??
coolerking76
Re: smoking bongo
no i didn't drive it with a burst rad smoke started after it had been fixed but not correctly vented, and no temp gauge was fine .
any more thoughts guys?
coolerking76
Re: smoking bongo
bit of an update now got the bongo back from garage it is very chuggy to start when cold then kicks out a tone of white smoke but as soon as she has warmed up the smoke clears with the odd puff when sat at the light ect,
Re: smoking bongo
that still reads as if glow plugs are not working
coolerking76
Re: smoking bongo
they have just been changed still same prob mate
- westonwarrior
Re: smoking bongo
Are you loosing any coolant at all?
Re: smoking bongo
can you use a test light or voltmeter to confirm the glow rail gets power
coolerking76
Re: smoking bongo
not sure about coolant and 11.9 v on the rail.
coolerking76
Re: smoking bongo
ok guys bit more of an up date NO coolant left at all, and a large very slightly oil feeling water mark on my drive
Re: smoking bongo
Sounds like you need to get it taken to a bongo savay garage (on a flat bed) and find out where the system is loosing coolant. Maybe somebody who knows your area better could advise on garage options? Best of luck for an easy and innexpensive fix
- haydn callow
Re: smoking bongo
If the tanks empty....don't drive it....even if you fill it up you will have air in there.
coolerking76
Re: smoking bongo
A turn for the worst found out the water is coming out the exhaust think the head may be cracked if you agree where is the best place to get replacement ?
