Broken manifold stud help!
Hi, seems quite a common problem, my front manifold stud has broken off an is making the lovely whistling sound. As it seems quite common I was wondering if anyone could give me any help with how to fix it. What do I need to remove to get the manifold off and get access to the stud, also any tips on the best way of removing the old broken one. Many thanks
- haydn callow
Re: Broken manifold stud help!
Do a search on here.....broken manifold stud.....loads of info
tomwharf
http://www.igmaynard.co.uk/bongo/Forum/ ... =3&t=41210
make sure that you follow the advice on the factsheet, especially regarding not breaking in to the coolant system!
Cheers, T
Cheers, T
- haydn callow
the stud can be extracted and replaced without removing anything....just swing the alternator out of the way
