Broken manifold stud help!
se3454
Post by se3454 » Wed Jan 18, 2012 8:07 pm
Hi, seems quite a common problem, my front manifold stud has broken off an is making the lovely whistling sound. As it seems quite common I was wondering if anyone could give me any help with how to fix it. What do I need to remove to get the manifold off and get access to the stud, also any tips on the best way of removing the old broken one. Many thanks
Re: Broken manifold stud help!
Post by haydn callow » Wed Jan 18, 2012 10:38 pm
Do a search on here.....broken manifold stud.....loads of info
Post by Northern Bongolow » Thu Jan 19, 2012 4:07 am
tomwharf
Post by tomwharf » Mon Jan 23, 2012 2:07 pm
http://www.igmaynard.co.uk/bongo/Forum/ ... =3&t=41210
make sure that you follow the advice on the factsheet, especially regarding not breaking in to the coolant system!
Cheers, T
Post by haydn callow » Mon Jan 23, 2012 3:15 pm
the stud can be extracted and replaced without removing anything....just swing the alternator out of the way
