steve480
Post
by steve480 » Sat Jan 02, 2010 6:04 pm
hi all,
got a strange problem with the main cooling fan at front of engine. when i turn key to ignition on position the fan fires up every time. got a new head fitted 2 months ago, i ordered a new temp sensor which was situated just at hand brake. this was the wrong part at a cost of £58 from bongobits. sent it back so should get my money back. my mechanic had to solder the temp gauge on cylinder head which if im correct controls the temp gauge inside cab. is there another sensor that controls the main cooling fan & where is it located ??? if i replaced that would it resovle the problem? just replaced altenator as well & was told by auto electricion that my liesure battery is needng replaced. as you can imagine in this cold weather i dont need the cooling fan to start up when i start engine. would appreciate any help thank you. all the best to all fellow bongoiers for 2010.
steve
wormey
Post
by wormey » Sat Jan 02, 2010 6:17 pm
I think mine does from starting, will have to check next time.
Daz and debs
mikexgough
Post
by mikexgough » Sat Jan 02, 2010 6:18 pm
Is your aircon switched on....... that would cause that .....just a thought
wormey
Post
by wormey » Sat Jan 02, 2010 6:27 pm
My aircon is always on, I will check though, next time I go a wandering
Daz and debs
steve480
Post
by steve480 » Sat Jan 02, 2010 6:43 pm
hi,
dont think its the aircon i never use it . definitely large cooling fan at front of engine that starts up. why would it come on when engine is cold ????? steve
dave_aber
Post
by dave_aber » Sat Jan 02, 2010 6:54 pm
I have the digital heater / aircon control panel, and if it's set to auto when I switch on, the front fan (A/C fan) kicks in straight away, even if the temp is set to 32°C. Switch it off, and it stops.
Those that understand
binary, and those that don't.
wormey
Post
by wormey » Sat Jan 02, 2010 7:29 pm
dave_aber wrote:I have the digital heater / aircon control panel, and if it's set to auto when I switch on, the front fan (A/C fan) kicks in straight away, even if the temp is set to 32°C. Switch it off, and it stops.
Mine to, it's always on auto.
Daz and debs
rita
Post
by rita » Sat Jan 02, 2010 7:38 pm
Hi Steve,
You have 3No fans 2 on the radiator and a scavenger fan at front of engine compartment.
You also have 3No sensors the one at the hand brake is a air temp switch that controls the scav fan.
The other two are the temp gauge and the cooling fan(s)
widdowson2008
Post
by widdowson2008 » Sat Jan 02, 2010 8:39 pm
rita wrote:Hi Steve,
Not too sure about the
'2 fans on radiator' being the only configuration.
I got a Bongo Friendee Service Manual from BF, and on page 35, it shows a pic of a radiator with 1 full width fan. No idea what vehicle its from but it may possibly be one of the later models. Maybe this is what steve480 has got.
Steve
rita
Post
by rita » Sat Jan 02, 2010 9:40 pm
widdowson2008 wrote:rita wrote:Hi Steve,
Does it not tell you what vehicle its from in the manual,and does it show the air con fan.??
Post
by g8dhe » Sat Jan 02, 2010 10:14 pm
Both the 1995 and the 1997 wiring manuals show 3 fans for all models, two up front on the radiator and the scavenger fan in front of the engine itself all three are controlled by the ECU/PCM which also has signals from the Air Conditioner be it a manual or electronic version.
widdowson2008
Post
by widdowson2008 » Sat Jan 02, 2010 10:45 pm
rita wrote:widdowson2008 wrote:rita wrote:Hi Steve,
No - I'll scan the pic and post in 10 mins. I assumed it is from a newer model. ....gimme 10 mins
Crap scan but it shows OK
Steve
rita
Post
by rita » Sat Jan 02, 2010 11:19 pm
widdowson2008
Post
by widdowson2008 » Sat Jan 02, 2010 11:35 pm
Any help?
This page actually suggests 2 fans - left and right (as expected.) So what is the pic of?
Steve
rita
Post
by rita » Sun Jan 03, 2010 12:02 am
Any help?
I don't really know what the the picture is about,(other than a sample photo)and I don't really know why you brought it up.
