Cibie Spots
Maxter
Cibie Spots
Post by Maxter » Fri Feb 16, 2007 1:23 pm
How do I get to the bulbs in these spot lights? It seems I need either a magic wand or sledge hammer!!!
M :D
trevd01
Post by trevd01 » Fri Feb 16, 2007 1:42 pm
Are these the sort with a chrome rim on the front?
If so I seem to recall this is how to do it:
Have a look to find a place around the rim (at the bottom?) where you can lever off the rim with a screwdriver.
chiefster1976
Re: Cibie Spots
Post by chiefster1976 » Mon Feb 19, 2007 10:07 pm
Maxter wrote:How do I get to the bulbs in these spot lights? It seems I need either a magic wand or sledge hammer!!!
M :D
If there the ones with plastic covers, then the plastic covers just pull off.Not fixed....Then there is ONE screw on the underside of the spot....take that off and the whole light will come off....push to one side the retaining clip and bobs your uncle f****s your aunt unplug the wire and take out the light....
Maxter
Post by Maxter » Tue Feb 20, 2007 9:17 pm
Mine are the latter, I'll give it a go.
Cheers all
M :D
