QD battery clamps
vanvliet
QD battery clamps
Post by vanvliet » Wed Feb 14, 2007 9:52 pm
I use these for my leisure battery .Might be available cheaper elsewhere!Ithink I paid £6 from a caravan shop
http://www.maplin.co.uk/Module.aspx?Mod ... doy=search
madmile
Post by madmile » Wed Feb 14, 2007 11:45 pm
Thats a very good price - My trade motor factors charge more than that- admitedly its not a big part of their range, but they are wholesalers!
Off to maplins for the next set.
Post by mikeonb4c » Thu Feb 15, 2007 1:41 am
Waddya need to disconnect your terminals for vanvliet? :?
Veg_Ian
Post by Veg_Ian » Thu Feb 15, 2007 8:48 am
Got some similar from Towsure last year, cheaper than that but you would need to check current prices. Why use them? About as cheap as standard without faffing about with spanners.....
vanvliet
Post by vanvliet » Thu Feb 15, 2007 9:27 am
I have them fitted to the leisure battery which needs regular topping up from a charger . I had them fitted to my caravan battery too .
I just find it hassle free to use butterfly nuts on the battery clamp and easy disconnection of the battery itself using these terminals No need to hunt around for spanners .I am a lazy sod
Post by mikeonb4c » Thu Feb 15, 2007 10:27 am
Gotcha - honest answer - thanks! They are a nice touch
Post by Simon Jones » Thu Feb 15, 2007 3:04 pm
Interesting that they use blue for negative - surely this is totally non-standard.
Post by bigdaddycain » Thu Feb 15, 2007 5:04 pm
I,m not really clued up on all this leisure battery lark, but my brother in law fitted a leisure battery to his bongo,and he didnt have to charge the leisure battery, it charged when he drove the bongo,and his interior lights and radio worked without the ignition on. There was a solar panel stuck in the hatch window in the roof also, which apparently charged the batteries when the sun shined?? 8) Im not sure if the last bit was a wind up or not, but there was a solar panel there :?
vanvliet
Post by vanvliet » Thu Feb 15, 2007 7:31 pm
See Dandy W 's update post on split charge relay's and leisure batteries The man knows his stuff
''alternator only really gives about 75/80% of charge and always best to mains charge every so often. ''
