The Blind over my side door has stuck, just makes a whiring noise when you try to open/close on the switch and wont budge with a reasonable amount of handpower.
Should I try to force it a little more ?
It was working fine and dandy one day and then kaput the next!
Russ
Stuck electric Blind
Thanks colin,
just to be clear I have already pulled with some pressure but not the maximum I can. I guess that if if doesnt budge with more pressure on it then it might snap the blind itself - which seems to flex like plastic?
I will cross my fingers that others can clarify before giving it a go at the risk of totally buggering up (....which is something that I normally do!)
dont do it..........
please dont pull it......thats what i did and then i snapped the rod at the bottom,
mine was sticking coz the motor needed freeing up first, got the garage to do this....
still got my snapped bits, so please please please dont pull it and force it.........
Thanks Everyone
Pippin - It is stuck more than normal, all the others are stil farily free on manual
Thanks - what was involved in this, I ll take it down to SR motors but any info I can give them to get them started will help. Was it easy to get to?
Thanks again
Thanks again
