My bongo does not have rear speakers in so am going to fit some myself.
I removed the rear drivers side panel and was hopping to see the wires already there ready to fit the speakers.....
None in site......
So not to be out done easily i pulled the stereo out and located the four rear + & - speaker wires.
i had a wire converter plug fitted for my sony cd player.
I.e bongo original plug then new converter plug with wiring links to the stereo plug, then into the stereo..hope your still with me...
The mazda original plug colours for the rear speakers are as follows:
+ rear left= yellow with red stripe.
- rear left= solid orange.
+ rear right = green with orange stripe.
- rear right = solid white..
NOw i tried to trace these wires..from back of the stereo down to passenger footwell then disaappers under the upright trim( i removed this to follow the wire) there is a plug behing this trim but just loops back up the trim( hence no need to remove the trim in the first place).
then they move up behind the centre console and into a conduit which splits off in to two....
Now from here i have no idea where they go..Not going to attempt removing any dash parts....
1. Does anyone know where these wires can be located so i can hopefully hook up some wire to use my new speakers?
I hopping that there is a plug somewhere near the rear of the van i can ajoin to..
2. Are these colour wires actually the rear speaker wires????
If there is nowhere to hook up to then i think i may just cut the wires near the footwell and just run some new wire from there back to the rear of the van.....
Thanks guys....
