Auto Box Error Codes
BongoDave
Post by BongoDave » Sun Dec 10, 2006 9:18 pm
Can any one help me i've had the flashing hold light come on my bongo i've read the fact sheet about this and have come out with this code 1 LONG 1 SHORT 1 LONG 2 SHORT and help would be appreciated?
Many Thanks
Dave
Peg leg Pete
Post by Peg leg Pete » Sun Dec 10, 2006 9:29 pm
Welcome Dave, I will check out the code for you, Our bongo has an intermittent flashing hold problem, linked to the chip on the speedo, I pull up turn off the ignition,restart and away we go :wink:
Image Pete
Post by Doone » Mon Dec 11, 2006 2:25 pm
There are 2 factsheets which give advice on this - 'Hold Light' and 'Transmision Fault Codes'.
BongoDave
Post by BongoDave » Tue Dec 12, 2006 9:58 am
I've looked at both the fact sheets and cant seem to find the codes it looks like code 11 and code 12 is that right?
Post by Ian » Tue Dec 12, 2006 10:22 am
Look on page 2 of the transmission fault code fact sheet. There is no code 11, but code 12 is the throttle position sensor.
BongoDave
Post by BongoDave » Tue Dec 12, 2006 3:46 pm
Does any one know where the throttle position sensor is located as i can borrow a friends Bongo and change it over before i buy a new one
Many Thanks
Dave
Post by Ian » Tue Dec 12, 2006 4:18 pm
Try the search facility. Use the search term "Throttle AND sensor" (exactly as written but without the quote marks).
http://www.igmaynard.co.uk/bongo/forum/ ... de=results
