2.5 Diesel - Shift Solenoid replacement
Mheitman1
Post by Mheitman1 » Sat Dec 28, 2024 11:15 pm
Hi all, recently purchased a 1997 bongo and having a persistent gearbox fault where the hold light is flashing and not changing into 4th gear. All other gears work fine and speed isn't limited. No other gear boxes issues afaik, shifts smoothly and correctly,. Speedo and tacho working fine.
Read the ECU and it's coming up with a 3-4 shift solenoid error.
Just ordered the replacement solenoid pack and plan to fit it in the next week, does anyone have any tips/instructions?
Can't find much information around apart from what bolts on the valve body to remove and a few little bits on some posts.
Thanks in advance!
Re: 2.5 Diesel - Shift Solenoid replacement
Post by g8dhe » Sun Dec 29, 2024 9:57 am
Welcome aboard!
Have you done a search here on BF ? search.php?keywords=shift+solenoid&term ... mit=Search seems to come up with several useful links and this thread viewtopic.php?p=701546&hilit=shift+solenoid#p701546.
There is a also a Fact Sheet in the members area on the subject.
