Temp Gauge not working - which sensor to replace?
Kernowel
Post by Kernowel » Fri Sep 06, 2024 2:57 pm
My temperature gauge has stopped working (since a coolant leak was fixed funnily enough). Any idea which sensor needs to be replaced, or is it both of them?
Sorry if this has already been asked. I did find a thread but the links were dead so I couldn't see which one
it was https://www.lushprojects.com/bongoparts ... no=.html#9
gilly99
Re: Temp Gauge not working - which sensor to replace?
Post by gilly99 » Fri Sep 06, 2024 4:23 pm
Ontop the head at the front - Heat Gauge 18-510.
It's not the wet one half way down the block, buried behind the inlet manifold.
Post by g8dhe » Fri Sep 06, 2024 7:26 pm
Its the one with a single Green wire at the front of the engine, location varies where on the front, diesel accessed from under drivers seat, petrol closer to the centre line as I recall.
Kernowel
Post by Kernowel » Sun Sep 08, 2024 1:35 pm
Thanks both. Another stupid question:
Why are there two different part numbers for the Heat Gauge 18-510 on the index? Is one for the petrol and one for the diesel variant?
JE151851X and KL011851X
Many thanks
Mike
Post by g8dhe » Sun Sep 08, 2024 1:38 pm
No, one feeds the dashboard display alone the single green wire and the other feeds the ECU engine temperature from the I suspect the oil in the crankshaft case.
