AC Clutch Click
Muffthebongoboi
AC Clutch Click
Post by Muffthebongoboi » Fri Aug 02, 2024 2:54 pm
Hi I have no AC and it doesn't Click when I press the AC button.......
Any ideas as to what it could be.? Many thanks.
Tym
My Bongo is Called *VAN-DIESEL*
Re: AC Clutch Click
Post by g8dhe » Fri Aug 02, 2024 4:29 pm
Is there a belt on the pulley ? When you operate the AC On does the clutch engage and turn the compressor ?
Muffthebongoboi
Re: AC Clutch Click
Post by Muffthebongoboi » Thu Apr 24, 2025 11:52 pm
Hiya sorry for late reply I lost my login details. I have the belt and pilly etc. but no nothing engages, and my revs stay the same! Wondering if it's electrical issue.
Can't find a tidy fuse diagram anywhere.i used to have a few original ( English ) bongo manuals! No idea where their gone now either!
Re: AC Clutch Click
Post by g8dhe » Fri Apr 25, 2025 8:28 am
There is a good chance its electrical, you have turned on the Aircon system inside I assume ?
If so check that the clutch plug is actually connected under the bonnet, it may have been removed to prevent it operating if the compressor has failed. Its a two wire lead from the very front of the compressor. If it is connected then check to see if you are getting power to it when the Aircon system is turned on and in operation.
Return to “Devon & Cornwall/Kernow”
