Thermostat Housing flange 2.0 Torque setting
kton2002
Post by kton2002 » Thu Jul 13, 2023 4:31 pm
Afternoon, does anyone know the torque setting for the 2 x nuts that hold the thermostat flange on to the engine? Thanks
Re: Thermostat Housing flange 2.0 Torque setting
Post by g8dhe » Thu Jul 13, 2023 4:58 pm
looks like 19-25N-m or 1.9-2.6kgf-m
kton2002
Post by kton2002 » Thu Jul 13, 2023 5:13 pm
Thanks Geoff that is very helpful.
Wondering if i need to drain the entire system to do this, it says on that page to drain it but as its near the top i would assume i can just catch whatever comes out as best i can and then refill the expansion tank.
Post by g8dhe » Thu Jul 13, 2023 5:52 pm
Well the 2l is self bleeding so its not so bad to refill it and clear the engine of air, so maybe drain it and save the coolant to later refill maybe ?
Flanners
Post by Flanners » Sat Dec 02, 2023 9:18 am
nice post need to do mine, got the genuine thermostat; engine is running cold
Flanners
Post by Flanners » Tue Jan 02, 2024 12:09 pm
Purchased an OE thermostat (no gasket supplied), took the old one off and the original seal/gasket fell to bits with most welded onto the thermostat housing, had to scrape the old one off. Thought I could bodge it but no, purchased an MX5 housing gasket (same as Bongo it seems) and all is good again, up to temp quickly once more. Parked van on slope so minimal coolant loss and no need to drain system, couple of times round the block and a small top up all sorted.
Post by Bob » Tue Jan 02, 2024 2:37 pm
Nice one. :)
