Are these a thing?
The van we have had for a year has multiple fixing holes in the alloy rims fitted. There are 8 holes although two of these are Siamese in the same recess. The wheels fitted are 16 inch with a low pro tyre and I wanted something a bit more conventional, not least to match the 15’ spare I have under the floor.
The replacement alloy wheels also have this multiple fixing arrangement and I understand it is for alloy wheel makers to offer the same wheel on alternative pcd. I’m assured the wheels I have bought are designed to be like this and it’s quite safe but I wanted a second opinion.
I can find references to dual stud fixing on American websites but none on UK suppliers and no wheels advertised on eBay reference it. I have however seen plenty of pictures of bongos with multiple stud holes so either some one has been busy with a drill or this is perfectly normal and I just haven’t come across them before. I have never bought after market alloys before so I guess I’m still learning.
						Dual fit Alloys
Re: Dual fit Alloys
Please make sure that these replacement road wheel have been approved and added to your Insurance Policy, failure to do so could render your Policy Void. Take care.
						Re: Dual fit Alloys
I'm replacing alloy wheels with alloy wheels therefore my insurance policy is competely unchanged - in fact I'm going closer to standard as this is a 15" wheel where as before they were 16"
						Re: Dual fit Alloys
That great, as long as your insurance policy shows the modification you should be covered, but to be on the safe side I would give them a wee phone call of your intentions. Good luck.
