Coil light flushing
NoiseAngelo
Coil light flushing
Post by NoiseAngelo » Thu Feb 10, 2022 8:46 pm
On my 2002 diesel 2,5 the coil light won’t stop flashing even while driving.
My mechanic says he doesn’t have the old OBD plugs to diagnostic.
What shall I do? I was planning to hit the coast over the weekend.
Thank you guys.
ever after.
Re: Coil light flushing
Post by ever after. » Thu Feb 10, 2022 9:11 pm
This actually happened me last week after changing the glowplugs (along with the scavenger fan switching itself on intermittently)
Turned out I forgot it plug in a connector beside the handbrake
NoiseAngelo
Post by NoiseAngelo » Thu Feb 10, 2022 11:35 pm
Ooo I’ll check the handbrake compartment… I just did a service 2 days ago maybe something is pinched there. Thank you
Post by g8dhe » Fri Feb 11, 2022 9:49 am
he Glowplug light flashing indicates as the garage has said that the ECU is reporting a fault. You read the error code by using a link wire and lamp to see the flashes from the OBD socket. There is a Factsheet in the members area detailing the steps to read the code.
