Fuel shut off Solenoid
Bongonaughty
Post by Bongonaughty » Sun Aug 29, 2021 9:29 pm
Hi All,
Engine wont shut off with key. :x
Got it stopped by blocking air intake and revving it.
Fuel shut off solenoid is suspected.
Part has 3 codes: Zexel 146650-4320, Bosch 9 461 612 134 and Mitsubishi MQ906099.
I cant find one anywhere online for the life of me.
Out of stock everywhere.
Any leads would be appreciated.
Re: Fuel shut off Solenoid
Post by teenmal » Mon Aug 30, 2021 11:20 am
This is the PN 093324300B you might need to get it cross-referenced at the shop.
Post by teenmal » Mon Aug 30, 2021 11:42 am
teenmal wrote: Mon Aug 30, 2021 11:20 am This is the PN 093324300B you might need to get it cross-referenced at the shop.
Have you tried to remove the solenoid and examine / test it .
Bongonaughty
Post by Bongonaughty » Tue Aug 31, 2021 10:39 am
No not yet, i wouldn't even know here to find it in the van to be honest!
Post by g8dhe » Tue Aug 31, 2021 11:16 am
The wire is the feed to the fuel cut-off valve
Bongonaughty
Post by Bongonaughty » Tue Aug 31, 2021 11:21 am
Thanks ill take it off and take it apart maybe something as simple as the spring has broken?
