Which glow plugs?
langtoftnick
Which glow plugs?
Post by langtoftnick » Tue Aug 03, 2021 7:48 pm
Bongo 1995 2.5 Wlt vin sgl5 104891… bongo shop says 93 mm plugs, as do other sources, but mine has 102mm…. How can that be?
Any info gratefully received!
Nick
Re: Which glow plugs?
Post by Bob » Tue Aug 03, 2021 8:12 pm
Maybe the wrong ones were fitted.
Post by g8dhe » Tue Aug 03, 2021 8:25 pm
The extra length is outside the engine.
It just means the busbar is further away from the head and less likely to short out which the shorter ones do if not checked carefully!
langtoftnick
Post by langtoftnick » Tue Aug 03, 2021 9:52 pm
Huh? Surely it’s the length of the heater element which means if it’s too long it will smash into the top of the piston at tdc?
Post by Northern Bongolow » Tue Aug 03, 2021 10:25 pm
No, the internals are the same, the difference is above the head/ thread.
langtoftnick
Post by langtoftnick » Wed Aug 04, 2021 8:05 am
Oh, ok, who knew? You lot, as usual! Thanks for yr help.
