Hi guys hope you are all well,
my drivers door seems to have dropped so have to lift to close, does anyone know of a fix, or how to remove the door.
Many thanks in advance
Tony
Drivers door dropped
- turfite9999
- Bongonaut
Re: Drivers door dropped
I know the A post is just a bit of bent tin, really thin, it's either been bent or the bottom maybe rotten and it's moved forwards allowing the door to move downwards/forwards.
This is a well know rot spot behind the front wheel, front end of cill etc
- turfite9999
- Bongonaut
Thank you I will look at that Vanessa
- turfite9999
- Bongonaut
Hi guys does anyone have any experience of removing drivers door so I can get at the hinge that`s connected to the wing or near the wing,
Thank you in advance
Tony
Tony
I can only think support it, maybe ropes tied to something, then undo the bolts.
Obviously disconnect the loom first.
- turfite9999
- Bongonaut
Thanks Bob
- turfite9999
- Bongonaut
sorry to go on about this, does anyone know if you have to take off the wing to replace door hinge rods please I`m struggling to get info, and does anyone know what bush/rod size to get
many thanks
Tony
many thanks
Tony
