Drivers door dropped
turfite9999
Post by turfite9999 » Wed Mar 31, 2021 3:30 pm
Hi guys hope you are all well,
my drivers door seems to have dropped so have to lift to close, does anyone know of a fix, or how to remove the door.
Many thanks in advance
Tony
Re: Drivers door dropped
Post by Northern Bongolow » Wed Mar 31, 2021 7:32 pm
I know the A post is just a bit of bent tin, really thin, it's either been bent or the bottom maybe rotten and it's moved forwards allowing the door to move downwards/forwards.
This is a well know rot spot behind the front wheel, front end of cill etc
turfite9999
Post by turfite9999 » Thu Apr 01, 2021 7:48 am
Thank you I will look at that Vanessa
turfite9999
Post by turfite9999 » Wed Apr 07, 2021 12:15 pm
Hi guys does anyone have any experience of removing drivers door so I can get at the hinge that`s connected to the wing or near the wing,
Thank you in advance
Tony
Post by Bob » Wed Apr 07, 2021 12:42 pm
I can only think support it, maybe ropes tied to something, then undo the bolts.
Obviously disconnect the loom first.
turfite9999
Post by turfite9999 » Wed Apr 07, 2021 12:58 pm
Thanks Bob
turfite9999
Post by turfite9999 » Thu Apr 08, 2021 4:34 pm
sorry to go on about this, does anyone know if you have to take off the wing to replace door hinge rods please I`m struggling to get info, and does anyone know what bush/rod size to get
many thanks
Tony
Post by Doone » Sat Apr 10, 2021 11:09 am
Discussion continues here: viewtopic.php?f=3&t=77862
This post now locked. :)
