oil leak
gasman50
oil leak
Post by gasman50 » Fri Apr 17, 2020 10:52 am
Hi i have just noticed my 2002 v6 has a slight oil leak below radiator on the drivers side there are two pipes with oil on them and oil on pan underneath. What are these pipes connected to? Would it be a easy job to repair? Hope someone can help
Many thanks Mark
2002 2.5L V6
Re: oil leak
Post by Bob » Fri Apr 17, 2020 11:15 am
They'll be the pipes that run the gearbox fluid through the heat exchanger in the bottom of the radiator.
Don't know if it's a pipe or the rad leaking, but a new rad will mean bleeding the system. :?
There is a dipstick to check level in auto box, driver's side rear. Check with engine up to temp, running, and cycle gear selector a few times first.
Hope that helps.
gasman50
Re: oil leak
Post by gasman50 » Fri Apr 17, 2020 12:04 pm
fluid level seems ok at the moment i will check pipes and radiator thanks for your help
2002 2.5L V6
