underbonnet fuse box
turfite9999
Post by turfite9999 » Mon Oct 14, 2019 5:47 pm
Hi Bongo buddies hope you all keeping well
I was wondering how hard is it to fit a under bonnet fuse box. On my ABS fuse a blade is missing so only one connection for the fuse.
Any help will be appreciated. Thank you
turfite9999 :(
Re: underbonnet fuse box
Post by g8dhe » Mon Oct 14, 2019 6:05 pm
Which fuse has lost its connector ? Whats happened to it ? Is the wire still there ?
turfite9999
Post by turfite9999 » Mon Oct 14, 2019 6:08 pm
its 14 the ABS no it's the blade thats missing g8dhe the one you show highlighted the big one
Post by g8dhe » Tue Oct 15, 2019 9:18 am
Slightly confused then;
The BLADES are the parts on the fuse, if one is missing then replace the fuse.
The fuse connector (socket) is mounted in the fuse holder, and has the wire for the fuse terminated on it, if it is missing then what has happened to it and where is the wire that terminates on the connector ? As without the wire your not going to get very far ....
turfite9999
Post by turfite9999 » Tue Oct 15, 2019 10:02 am
Thanks for that Geoff
Its not the fuse its the blade coming from the fuse box that the fuse goes into. Dont know about the wires though I may have to take apart.
Turfite
turfite9999
Post by turfite9999 » Tue Oct 15, 2019 2:36 pm
Hi again trying to send you a photo but cant seem to resize image sorry
Post by g8dhe » Tue Oct 15, 2019 3:37 pm
Ah thinking about it those fuses are females with the connector on the fuse end and the blades inserted in fuse block of course.
So is that one or both the blades are missing in the block ? They are might have been forced down if someone has tried to force a fuse in, the block can be released with the nuts at the ends.
turfite9999
Post by turfite9999 » Wed Oct 16, 2019 4:32 pm
Hi Geoff trying to send you photo but even resizing dosnt work if I had your email that may work thank you anyway
turfite9999
Post by turfite9999 » Fri Oct 18, 2019 2:47 pm
Hi geoff I hope you get this pic please let me know thank you
turfite9999
Post by turfite9999 » Fri Oct 18, 2019 2:48 pm
it looks like you could just slot a blade in
Post by Bob » Fri Oct 18, 2019 3:06 pm
Could it have pulled out with the fuse and still be stuck inside it?
turfite9999
Post by turfite9999 » Fri Oct 18, 2019 4:08 pm
possible bob just never noticed
