Post
by g8dhe » Tue Oct 15, 2019 9:18 am
Slightly confused then;
The BLADES are the parts on the fuse, if one is missing then replace the fuse.
The fuse connector (socket) is mounted in the fuse holder, and has the wire for the fuse terminated on it, if it is missing then what has happened to it and where is the wire that terminates on the connector ? As without the wire your not going to get very far ....
