The V6 is running a bit rich, so thinking of possible causes. First I've recorded the fault codes (see my other thread requesting help with reading the sequence of flashes).
In the mean time, the other avenue was thinking of temperature sensor issues. I.e. if the sensor is faulty, the engine will think it's cold and run rich. There are other possibilties such as MAF sensor / lambda but these are more expensive items.
So, can you tell me which sensor (or sensors) are used by the ECU for adjusting the fuelling, and where is it/they on the V6? New sensors seem cheap, so I might try replacing.
Thanks in advance !
