V6 and temperature sensors
Gripped
Post by Gripped » Fri Sep 20, 2019 3:34 pm
Hi all
The V6 is running a bit rich, so thinking of possible causes. First I've recorded the fault codes (see my other thread requesting help with reading the sequence of flashes).
In the mean time, the other avenue was thinking of temperature sensor issues. I.e. if the sensor is faulty, the engine will think it's cold and run rich. There are other possibilties such as MAF sensor / lambda but these are more expensive items.
So, can you tell me which sensor (or sensors) are used by the ECU for adjusting the fuelling, and where is it/they on the V6? New sensors seem cheap, so I might try replacing.
Thanks in advance !
=D>
Flanners
Re: V6 and temperature sensors
Post by Flanners » Fri Sep 20, 2019 4:52 pm
what are the plugs like?
Gripped
Post by Gripped » Sat Sep 21, 2019 9:54 pm
Plugs are all OK. Same grey tinge to the electrodes.
Anyone know the temp sensor locations?
Gripped
Post by Gripped » Sun Sep 22, 2019 10:27 pm
So looking for the air intake temperature sensor, if anyone knows the location or the part number?
Many thanks
Post by g8dhe » Sun Sep 22, 2019 10:55 pm
The wiring diagrams and part diagrams are all online;
http://www.g8dhe.net/bwm - bear in mind you need Flash enabled in Chrome,
http://www.lushprojects.com/bongopartsmk2/
Gripped
Post by Gripped » Mon Sep 23, 2019 5:48 pm
Hi - thanks for those.
I've been digging, and as the MAF is a 5 pin unit, I think it has a temperature sensor built in. In fact you can see it as a little probe inside the MAF housing. So I guess that an error code for the MAF will also throw an error for the intake temperature.
I've cleaned the MAF, and the van is silky smooth and quiet. But it's always been pretty smooth.
