Hot cold air blower running slow
johnkatepages
Post by johnkatepages » Wed Aug 28, 2019 4:57 pm
My cab fan is gradually blowing slower and slower. When I first had my bongo the air flow on full would be very strong now it's very weak. I can't find any filters in the air ducts and nothing seems to be blocked. Is there anything else to try.
Re: Hot cold air blower running slow
Post by g8dhe » Wed Aug 28, 2019 10:38 pm
There aren't any filters as such, a common problem is water getting into the motor and causing corrosion, the water comes from the windscreen scuttle plate because the drain hole blocks up. This set of images shows you what needs cleaning if its the motor http://www.g8dhe.net/bongo_images/air_fan_cleaning/
johnkatepages
Post by johnkatepages » Thu Aug 29, 2019 6:34 am
Thanks very much. Will give that a try.
