Reversing camera install
ognob
Post by ognob » Thu Feb 21, 2019 9:59 pm
Got a camera I’m probably going to mount by the number plate lights.
Any suggestions / tips on cable route recommendations to get it to the head unit
Thankyou
Re: Reversing camera install
Post by g8dhe » Thu Feb 21, 2019 11:00 pm
Much better view IMHO if mounted higher looking down, otherwise you lose depth perspective, I mount mine on the highlevel brake light.
TheLongRoad
Post by TheLongRoad » Fri Feb 22, 2019 2:29 pm
I put mine above number plate. Keeps it out of the rain. Cable can go through existing hole behind number plate. Feed it up through tail gate and through the flexi rubber thing with the other cables. Now feed cable to front behind passenger side trim up at roof level. You can just tuck it in without removing anything. You can hide it under passenger door seal and then you’re able to pass it under dash to head unit. :wink:
2002 Friendee 2.0 ltr Petrol.
winchman
Post by winchman » Fri Feb 22, 2019 6:45 pm
Mine was routed through the high-level brake light and along the head lining I made a pod to hold a 7" screen by the rear view mirror
If I was doing another I would mount two cameras one facing the floor for parking and one facing backwards, the modern screens easily toggle between the two
https://www.ebay.co.uk/itm/7-Monitor-HD ... rk:18:pf:0
