Rear wheel spin and noises from 4x4 Bongo
jaycey001
Post by jaycey001 » Fri Dec 14, 2018 2:47 pm
Hi all
Off to Devon tomorrow from Suffolk in our Bongo. I have noticed that when the van is on full lock there is a "slipping" feeling from the rear wheels, and its not too difficult to spin the rear wheels when accelerating out from a stand still. Well, it feels like its a wheel spin but may not be.
Its also intermittent and more noticeable on uneven or loose ground.
I suppose this could be the VC playing up, but my main question is will I be causing any long term damage by driving several hundred miles over the next week?
I have 4 new tyres of the correct size for front and rear wheels and its a 4x4 auto 98 with about 90k on the clock.
Many Thanks
James
Re: Rear wheel spin and noises from 4x4 Bongo
Post by g8dhe » Fri Dec 14, 2018 3:33 pm
The VC only affects the drive to the front wheels (assuming it hasn't failed of course). If there is a fault - not sure there is - then it sounds more like a rear differential problem, maybe you have a Limited Slip Diff. (LSD) which is an option and can be checked by looking for a yellow sticker on the casing ? Might be worth putting your VIN into the production database and see what it was originally fitted with see here http://mazda.epcdata.ru/
