coolant alarm issue
knpenny
coolant alarm issue
Post by knpenny » Tue Apr 10, 2018 8:22 pm
on the topic of the epic service, mind the coolant alarm i installed, well lets see if anyone has a clue as to whats going on with this one.
All seemed well test n all that but bizzarely when i screw the screw half way in with no coolant in the bloody thing stops beeping and flashing, nothing,
starts to go quieter then after about 5cm it just stops. :idea:
i cannot for the life of me figure this out, test button still activated and it works when not in the tank but half way in, sweet F.A. :x
Anyone any ideas???? as i now basically have a fancy flashing light and beep on command but no protection from the dreaded coolant fail.
Bongology, the study of all things bong. The bongologist. :shock:
Billybongo123
Re: coolant alarm issue
Post by Billybongo123 » Tue Apr 10, 2018 8:35 pm
Is the screw hitting an internal bulkhead or summat?
We love our rusty Bongo "Billy", despite his many faults!
Billybongo123
Post by Billybongo123 » Tue Apr 10, 2018 8:37 pm
Something must be lowering the resistance?
knpenny
Post by knpenny » Tue Apr 10, 2018 8:52 pm
its bizzare its when i get to a certain point and it just stops. I ddnt feel that i had hit the internal bulkhead when screwing, and it did it when there was no coolant in it :idea:
knpenny
Post by knpenny » Tue Apr 10, 2018 9:40 pm
Amazing the seller got back to me he also thinks its an internal baffle i am hitting thats causing resistance. looks like i'll be drilling another hole #-o not sure how i'll plug the old one, maybe just get another screw and leave that one where it is :oops: also noticed the lesiure battery backet at back is snapped so i'll have to weld that or make another and just to add insult to injury got a brake light out, turns out that the lights been whacked befor and there's a great big hole at the top letting water in so i've bodged it for now with the lid off a sheeba catfood tinny thing and some of that silicone based sealant i had left over from the sump sealing :lol:
just glad the rest is finished tho :wink:
Billybongo123
Post by Billybongo123 » Tue Apr 10, 2018 9:57 pm
😂😂😂 you are just winging life. Top man.
Post by haydn callow » Wed Apr 11, 2018 12:08 pm
Just to make clear :- NOT ONE OF OURS
Post by haydn callow » Wed Apr 11, 2018 12:28 pm
Why would hitting a baffle affect the resistance, must be a hell of a long screw.
TheLongRoad
Post by TheLongRoad » Wed Apr 11, 2018 3:45 pm
@knpenny. Can’t you use a shorter screw rather than drill another hole?
2002 Friendee 2.0 ltr Petrol.
Post by g8dhe » Wed Apr 11, 2018 4:12 pm
On that type the screw goes in from the top and reaches down to the correct level for the tanks its being fitted to .... unless as you say it hits the side of a baffle plate and shorts out on the deposits on the baffle plate.
Post by haydn callow » Wed Apr 11, 2018 4:16 pm
It wouldn’t Short out on deposits otherwise the normal screw would Short on the inside of the drilled wall. I think!!
Post by g8dhe » Wed Apr 11, 2018 4:31 pm
Yer your right there Haydn, but it must be something on the surface which is conducting back down to the chassis by some means!
TheLongRoad
Post by TheLongRoad » Wed Apr 11, 2018 5:31 pm
g8dhe wrote: Wed Apr 11, 2018 4:12 pm On that type the screw goes in from the top and reaches down to the correct level for the tanks its being fitted to .... unless as you say it hits the side of a baffle plate and shorts out on the deposits on the baffle plate.
I see. I’ve not seen anything other than the Haydn on which I’d fitted on mine. I’ll leave this thread to the experts and learn :D
Post by g8dhe » Wed Apr 11, 2018 6:49 pm
These are the install instructions;
Post by haydn callow » Wed Apr 11, 2018 8:05 pm
There should be no need for the bottom screw or wire. Just earth the bottom wire to the chassis..
