I'm planning to do this in anticipation of having a rear kitchen conversion fitted later in the summer
Swapping bench seats
Not particularly technical I know, but I'm considering swapping the rear one-piece bench for the middle row split seat and having the 'new' middle row seat facing rearwards. Do I need to take out the runners and move those around or can I just unbolt and swap the seats over?
It strikes me that the one-piece seat will make a better bed base as it's a bit less bumpy!
Mark
Re: Swapping bench seats
Swapping the two benches is fine without changing the runners.
But .... The standard mechanism for releasing the runners is asymmetrical so to keep the ability to slide the reversed seat forwards and backwards you must
either reverse the runners as well (by removing them from the rail and putting them back in the other way round)
or by modifying the mechanism on the seat. (there have been discussions on this. You could sift through a search like reversing +(seat |seats) +(modification |runner |runners)
Choice depends on how often you'll want to change the seat's orientation. First option if this is a one-off, second option if a regular thing.
Chris with BertieB
Thanks for that, it's saved me a lot of time on a fruitless experiment.
Looks like I'll be swapping the runners around!
Mark
Useful links:Markas wrote:Thanks for that, it's saved me a lot of time on a fruitless experiment.
Sticky thread on reversing middle seat - this is the one I used, first ever job on my Bongo was to put seats back how Mazda intended!! http://igmaynard.co.uk/bongo/forum/view ... sing+seats
FAQ with links: http://igmaynard.co.uk/bongo/forum/view ... =43&t=9562
Chris with BertieB
