Fog light help for MOT
Katka
Post by Katka » Mon Jun 12, 2017 3:10 pm
Sadly, our 'van sadly failed its MOT this morning, primarily due to a leaky exhaust..... That's easily fixed, but the tester also wanted to see a tell-tail to show when the rear foglight is on. I took the switch out and there is a tiny bulb in it, which I tested and found to be working but so faint it is barely visible. Is this bulb a tell-tale or an illumination so that the switch can be found in the dark? If it's not a tell-tale, has anyone fitted one? If so, what's the best way to do this, or is a trip to Halfords for a new switch with a suitable bulb in it needed?
The good news is the tester commented on the good condition of everything else he saw.
wonkanoby
Re: Fog light help for MOT
Post by wonkanoby » Mon Jun 12, 2017 3:48 pm
http://www.ebay.co.uk/itm/Universal-Car ... Sw1vlUurGl
assuming its something like that i dout you can replace the bulb
Post by rita » Mon Jun 12, 2017 3:49 pm
Its a trip to Halfords or similar for a new compatible switch.(the light is a tell tale function )
Good Luck.
Post by Bob » Mon Jun 12, 2017 5:46 pm
Or you could just buy a dash board light form any car shop and take a live feed from the switch and earth the other side. :wink:
Should be cheap enough.
http://www.ebay.co.uk/itm/2x-12v-BLUE-L ... 2548.l4275
Katka
Post by Katka » Thu Jun 15, 2017 3:28 pm
Success. I popped into a Mazda dealer who found a switch & bulb in a discard bin but it too was too dim to be seen, so as suggested I put an LED across the switch terminals which did the trick. Thanks for the pointer. The main reason for MOT fail was a leaky exhaust, which they welded this morning and we now have a nice pass certificate, and a quiet Freda too.
If you are in the Guildford area and are looking for a reasonable garage, they not Bongo specialists (yet) but seem to know their stuff, Pantech on the A3 are worth a try.
Post by Bob » Thu Jun 15, 2017 8:59 pm
Good result. =D>
