Fuses
MalcW
Fuses
Post by MalcW » Mon Jun 05, 2017 11:53 am
Hi All
I've found that all of the fuses by the driver's door are really tight; by tight I mean I can't remove any of them using the little tweezer thingy that sits in the fuse board. Is this normal? Should I get something more substantial,pulling each one out in turn and cleaning them up? I wouldn't like to be out and about one day and need to change a fuse, only to find it isn't possible!
Cheers,
Malc
cmm303
Re: Fuses
Post by cmm303 » Mon Jun 05, 2017 12:45 pm
Assuming you are talking about the fuses inside by the drivers right knee.
They do feel a bit stiff especially if they have not budged for a while. They are only held in place by friction.
Chris with BertieB
MalcW
Re: Fuses
Post by MalcW » Mon Jun 05, 2017 12:50 pm
Hi Chris
Those are the ones, yes. On other vehicles in the past I've been able to remove fuses relatively easily, but these seem extra tight. It all started when I was looking for a suitable power supply to a low coolant alarm - which is fitted now but still not powered.
Cheers,
Malcolm
Re: Fuses
Post by Bob » Mon Jun 05, 2017 1:22 pm
I wonder if a quick squirt of contact cleaner would help. :)
Re: Fuses
Post by rita » Mon Jun 05, 2017 1:25 pm
Malcolm, you may need to give them a wee wiggle first (not too much).
How Old is your vehicle.
Good Luck.
Re: Fuses
Post by Northern Bongolow » Mon Jun 05, 2017 2:28 pm
im the same and fat little fingers dont help, i use a pair of small pointed nose pliers gently of course, mind you dont crack them.
Jimbobvfr400
Re: Fuses
Post by Jimbobvfr400 » Wed Jun 07, 2017 11:03 pm
If they're that tight then they're probably also really tarnished and mucky. For the price of a few fuses I'd probably just replace them, who could be bothered to clean fuses.
Jamie, Caroline and the kids.
2002 V6 Aero AFT
