ABS
noserider
ABS
Post by noserider » Tue Apr 25, 2017 4:38 pm
Is ABS standard in Bongos?
I was just looking under the bonnet and checking a few things and looked at the fuses. There are no fuses for the ABS?
Is that right???
Re: ABS
Post by Bob » Tue Apr 25, 2017 7:05 pm
Early ones don't have it, not certain if it was fitted to newer models. :wink:
Re: ABS
Post by rita » Tue Apr 25, 2017 7:20 pm
ABS is an optional extra, if you have ABS you will find the hyd unit and pipes under the bonnet (passengers side) .
Good Luck.
Bongolia
Re: ABS
Post by Bongolia » Tue Apr 25, 2017 8:04 pm
rita wrote:ABS is an optional extra, if you have ABS you will find the hyd unit and pipes under the bonnet (passengers side) .
Good Luck.
Or a little red skidding car light on the dash panel when you switch ignition on . If it aint blown :D
noserider
Re: ABS
Post by noserider » Tue Apr 25, 2017 8:07 pm
Good Luck.
Thanks I will take a look in the morning
