Is ABS standard in Bongos?
I was just looking under the bonnet and checking a few things and looked at the fuses. There are no fuses for the ABS?
Is that right???
ABS
Re: ABS
Early ones don't have it, not certain if it was fitted to newer models.
Re: ABS
ABS is an optional extra, if you have ABS you will find the hyd unit and pipes under the bonnet (passengers side) .
Good Luck.
Good Luck.
Re: ABS
Or a little red skidding car light on the dash panel when you switch ignition on . If it aint blownrita wrote:ABS is an optional extra, if you have ABS you will find the hyd unit and pipes under the bonnet (passengers side) .
Good Luck.
