Interior Trim Removal
Valkeerie
Post by Valkeerie » Wed Mar 29, 2017 9:43 am
I expect this is a dumb question, but I am paranoid about breaking something, and it is better to ask IMO.
I want to run a cable from the upper rear of my Bongo (for a solar panel) to the front. I would like to route the cable behind the trim over the windows.
I have removed the two passenger grab handles, and the seatbelt bolts. I haven't noticed any other fixings, and the trim seems both brittle and very secure.
How do I remove it? My Bongo is a 98 model.
Many thanks
Valkeerie
Re: Interior Trim Removal
Post by Bob » Wed Mar 29, 2017 9:48 am
Likely best to use a Trim Removal Kit:
http://www.eurocarparts.com/ecp/p/tools ... GwodNeQMPA
A quick Google will bring up other kits. :wink:
Use appropriate tool to gently pry the trim off.
Valkeerie
Post by Valkeerie » Wed Mar 29, 2017 9:52 am
Bob wrote:Likely best to use a Trim Removal Kit:
I appreciate the reply, but it doesn't help me. I need to know how the trim is secured - whether it is a stiff, pop-fit, or whether there are additional fastenings I have missed.
Post by rita » Wed Mar 29, 2017 10:13 am
You should be able to get the information you need here....
http://lushprojects.com/bongopartsmk2/
Post by Bob » Wed Mar 29, 2017 10:37 am
Well done Rita. =D>
Its under 'Body and Interior', then 'Window Trim'.
The little spring clip is shown bottom right.
Post by g8dhe » Wed Mar 29, 2017 1:18 pm
Once the handles are off its spring clips, just avoid pulling them out by using the trim itself otherwise the clips bend, then pop off in all directions - normally never to be found again ;-) So the pry tool is a good idea or a long flat screwdriver. You may also get quite a long way using a cable mouse to push down the channel, but I wouldn't want to be certain you would get all the way in one go!
Valkeerie
Post by Valkeerie » Wed Mar 29, 2017 2:55 pm
g8dhe wrote:Once the handles are off its spring clips, just avoid pulling them out by using the trim itself otherwise the clips bend, then pop off in all directions - normally never to be found again ;-) So the pry tool is a good idea or a long flat screwdriver. You may also get quite a long way using a cable mouse to push down the channel, but I wouldn't want to be certain you would get all the way in one go!
Thanks to Bob I have ordered the trim removal kit. Thanks to Rita I can see where the spring clips are located. And thanks to yourself for confirming it is some gawdawful spring clips - which I can't see or figure out until I have lost them.
I think I will take some photos if I can get that far. And yes, I was hoping I could feed most of the cable without popping the trim.
Thanks,
Valkeerie
Post by Bob » Wed Mar 29, 2017 4:32 pm
We can normally get there as a team. :lol:
Post by Bob » Wed Mar 29, 2017 4:33 pm
There's this kind of thing:
http://www.maplin.co.uk/p/maplin-cable- ... GwodsRoD_Q
Or I have has success with the plastic covered wire you hang net curtains on. This is really cheap. :wink:
Post by Bob » Wed Mar 29, 2017 4:34 pm
Hmmm... Don't know how it did that. :?
