ECU
psquiddy
ECU
Post by psquiddy » Thu Feb 16, 2017 4:44 pm
Does anyone know what the code numbers on the ECU mean?
I have a 2002 2.0l petrol that needs a new ECU but I am told that it needs a specific one that matches the numbers shown below and we cant find one that has anything like the same numbers/letters.
Over 300 free things to do in London
http://www.toplondondaysout.co.uk
Re: ECU
Post by Ian » Thu Feb 16, 2017 6:01 pm
What's your chassis number? (It's on the metal plate on the passenger door pillar)
psquiddy
Re: ECU
Post by psquiddy » Thu Feb 16, 2017 7:01 pm
SGEW 600224
Re: ECU
Post by Ian » Thu Feb 16, 2017 7:17 pm
The ECU you require is Mazda part number FF4918881B, which is indicated on the photo you posted. These are not available in the UK but are available from Japan. I have not done a formal price & availability check as it depends on currency fluctuations but it will be in the region if £1,300 plus VAT plus postage plus customs fees.
Try your local friendly Mazda dealer as you will avoid the customs fees and shipping from Japan, but it may take a while.
If that doesn't work I can get one for you in 2 weeks.
psquiddy
Re: ECU
Post by psquiddy » Thu Feb 16, 2017 7:30 pm
Blimey - I think I will wait for a second hand one to come up.
Posted in wanted section.
Bongolia
Re: ECU
Post by Bongolia » Thu Feb 16, 2017 9:25 pm
There are companies out there that repair ECUs and such like, run a Google search.
Have you tried a search through the old posts too?
Unrelated but any chance of an image of the plug side?
redrocket
Re: ECU
Post by redrocket » Fri Feb 17, 2017 9:19 am
There are loads of breakers around. I deffo would not be paying £1300 quid. Try here they have loads apparently for all models at £150
http://www.bongospares.co.uk/shop/engine/ecu/
Gasy
Re: ECU
Post by Gasy » Sat Feb 18, 2017 9:12 am
Re: ECU
Post by rita » Sat Feb 18, 2017 11:34 am
Re: ECU
Post by mikeonb4c » Sat Feb 18, 2017 11:49 am
Interesting. I couldn't spot Bongo in their catalogue but i wonder if that matters. Hopefully they can handle non catalogue items.
nth
Re: ECU
Post by nth » Sat Feb 18, 2017 12:41 pm
Whats the problem with your ECU ? How have you come to the conclusion the ECU is faulty?
95 2.5d 4WD AFT
Bongolia
Re: ECU
Post by Bongolia » Sat Feb 18, 2017 6:43 pm
Has anyone got an old knackered 2.0ltr Bongo ECU ?
I would be happy to pay a tenner or so and of course the P&P.
Re: ECU
Post by Ian » Sat Feb 18, 2017 6:53 pm
Make sure you get the right one. There are 5 different variants on the ECU for the 2 litre, Make sure the one you obtain is FF4918881B.
Bongolia
Re: ECU
Post by Bongolia » Sat Feb 18, 2017 7:12 pm
Dunno id this was for me?
Ian wrote:Make sure you get the right one. There are 5 different variants on the ECU for the 2 litre, Make sure the one you obtain is FF4918881B.
Are the number of connected pins the same and socket shape Ian?
I want it to make up a break out box.
Re: ECU
Post by g8dhe » Sat Feb 18, 2017 7:52 pm
There was a start to working out the diesel ECU a while back, the results to the point where he ran out of time are linked here http://www.g8dhe.net/bongo_images/Bongo ... inoman.zip
There were various threads have a look at the posts from rhinoman, problem with searching is terms have to be more than 3 characters which makes hunting for TLA's a problem!
